Huvitavat laiast maailmast
--kala-- kirjutas:
Zipp kirjutas:No Slava, link ka juurde ikka :D
vaata koledatest :mrgreen:
5 pluss :lol:
Cert85
Postitus Postitas Cert85 »
BMW 1M faster around Hockenheim than M3:
http://www.worldcarfans.com/11104253287 ... im-than-m3
symmi
Postitus Postitas symmi »
On veel mingit infot või foorumi linki selle kohta?
- e36 in progress...
Cert85
nos? :shock:
Penu
Postitus Postitas Penu »
peaks nagu dry nos kit olema. Ei saa aru, kas siis kütuse kompenseerib mootor ise või pihustavad ka seda juurde...
Njää, pole asjatundja :)
lugemist: Dry Nitrous Kit
The typical dry kit is one of the most simple kits available. The kit is called "dry" because it injects only nitrous into the engine, and not fuel. Generally, the dry kit is for people who want a set that allows them to let the ECU or computer automatically add appropriate amounts of fuel to compensate for the added nitrous into the motor. Usually you can get away with a dry nitrous system if you are confident in your car or truck automatically compensating fuel, you have a larger fuel system, or have a way of ensuring there is adequate fuel when the nitrous gets injected.
Wet Nitrous Kit
The typical wet kit is only of the more popular nitrous kits amongst enthusiasts. The wet kit injects both nitrous and fuel into the engine at the same time. As with the dry kit, you still need to have enough fuel in your fuel system for the wet nitrous system to be able to use while the nitrous is being injected. You can setup an external fuel pump specifically for this kit, so when the nitrous is activated, the fuel will come with the external fuel pump, bypassing the stock fuel system. This is a more elaborate wet nitrous system, but can be one of the most reliable setups.
Article Source: http://EzineArticles.com/2279980
Cert85
BMW Lo Rider (2009)
http://motorcycle-desktop-wallpapers.bl ... rance.html
http://www.motorcycledaily.com/2008/11/ ... mwconcept/
On ka teada, mis nendest masinatest lõpuks sai, kas jõudsid tootmisesse?
Ma kahjuks pole ise juttu läbi lugenud.
Masin(ad) mulle iseenesest väga meeldivad.
oja87
Postitus Postitas oja87 »
Kivissaar
Peamine sõiduk: Ducati
Telefon: 56863083
Postitus Postitas Kivissaar »
**** mind huvitaks kuidas ta kere ära toestas. omal kunagi oli sarnane idee e34jaga aga kahjuks ei jõudnud niikaugele.
vöiks ju arusaada et kui inimene enivei Passatiga söidab on ta juba eos elule käega löönud nii et vahet pole mis velg seal talvel all on
matu4
Peamine sõiduk: BMW e46 320d
Postitus Postitas matu4 »
oli
Postitus Postitas oli »
Hong Kongist siis selline huvitav pill
BMW 320 E46 '01
Tutvustavat juttu BMW elektriauto programmi kohta.
http://www.youtube.com/watch?v=fVlPqVx4lK4
coiff
Postitus Postitas coiff »
Vana asi aga huvitav lähenemine. BMW M5 Turbo
http://www.youtube.com/watch?v=mfIszlnp ... 4CBC5071AF
Bmw e39 523i ///M-sportpakett; Bmw e34 525i; Opel Calibra 2.0 i sport; Volkswagen Polo
Laupäeval algas 2011 Bimmerfest Rose Bowlil:
Autospies link
Autospies Gallery
Bimmerfestilt veel:
captjones1
Henri_J kirjutas:Pilt]
Madis.
Postitus Postitas Madis. »
Stirling Moss ei ütle sulle ilmselt mitte midagi?
Herr Moss oli võidusõitja.
Mismoodi see selle jubeda esiotsaga Z3-ega seotud on :lol:
Donald
Postitus Postitas Donald »
oo7 kirjutas:Herr Moss oli võidusõitja.
Vaata Striling Mossi McLaren SLR-i
Tean mis autost jutt, lihtsalt see Z3 ei näe kaugelt ka isegi natukene sarnanegi välja :mrgreen:
Stirling Mossi originaal võislusmasin veelvähem
Muidu tuuleklaasi idee on hea... Mingi Porche mudel on samuti madala klaasiga ja näeb päris uhke välja, lihtsalt see neerude ära kaotamine muutab selle auto koledaks
thiery
Postitus Postitas thiery »
Keegi kingitust tahab? :D
Sihuke kingitus oli täna Viimsis:
tarvo525i
Peamine sõiduk: E61 530d LCI
Postitus Postitas tarvo525i »
hea kink :D
HeavyCuda
Peamine sõiduk: põrkepall
Postitus Postitas HeavyCuda »
Kellegi rikka võsuke sai endale esimese auto ??? :mrgreen:
e36 coupe in progress.....
Üldiselt olen korduvalt seda siin foorumis maininud aga peab vist kordama... Teiste rahakotti ei ole vaja uurida ning mis vahet seal on kes kellele mida kingib. Pole mõtet kohe hakata sildistama "kellegi rikka võsuke". :roll:
HeavyCuda
Coley, ära seda nüüd isiklikuks tee :mrgreen: Ei või enam midagi naljaga poolekski öelda :roll:
Vaevalt, et keegi 333MUSi nr-ga autot oma tütrele või veel vähem pojale kingib - ju seal ikka üks tegus naiska mängus on ;)
Täna päeval sai kindlustuse ka;
Kehtiv alates 20.05.2011 16:33
Vaadake pilte parem - 328 Homage Concept
Järjekordne X6M Tallinnas
Ja kui rajapäevalt tulles rehvid autosse ei mahu
Keegi meie foorumist ehitab?
Bristol 400
Bristol 401
