BMW X3 '2011 F25
Postitatud: 15.07.2010 08:51 23
GENERAL:
To be produced in Spartanburg, South Carolina BMW plant
Expected to arrive in US BMW dealers by end of 2010
Compared to first generation X3: 0.5 inches (12mm) taller, 3.36 inches (83mm) longer, 1.1 inches (28mm) wider, 0.5 inch (12mm) more ground clearance. Wheelbase is 0.6 inches (15mm) longer - at 110.6 inches (2810mm).
INTERIOR & TECHNOLOGY:
Fourth generation iDrive / navigation
8.8 inch. high-resolution trans-reflective screen
BMW ConnectedDrive with Internet Access, HUD, Reverse Camera (incl. Top View)
Increased elbow and legroom from first generation X3.
Measured cargo volume between 19 and 56.6 cu.ft. (550 and 1,600 liters)
Fold down rear seats (60:40 split ratio)
ENGINES:
xDrive28i
3.0L inline 6-cylinder (N52 motor)
Magnesium/aluminum construction, valvetronic variable valve lift / double VANOS
240hp @ 6600rpm
230 lb-ft torque between 2600-3000rpm
0-60mph in 6.7 secs (preliminary quote)
Auto Start Stop Function
xDrive35i
3.0L inline 6-cylinder (N55 motor), direct injection, twin scroll turbo and valvetronic
300hp @ 5800rpm
300 lb-ft torque between 1200-5000rpm
7000rpm redline
0-60mph in 5.5 secs (preliminary quote)
150mph Top Speed (with optional sport package)
TRANSMISSION:
8-speed automatic transmission
Taller cruising gears to increase fuel efficiency
SUSPENSION / xDrive:
Third generation xDrive intelligent all-wheel drive
Integrated Chassis Management system
Normal torque split is 40% front / 60% rear
Torque transmitted to the front wheels is controlled by a multi-disc clutch that can be fully open (100% to the rear), fully engaged or at any level of partial engagement in between.
Double-joint spring-strut suspension at front / multi-link rear suspension
Servotronic speed-sensitive power steering
Optional Electronic Damping Control (EDC) adjusts shock absorbers to varying firmness levels
Optional Driving Dynamics Control (DDC) selector (incl. with EDC) allows three drive settings - Normal, Sport, and Sport Plus
pildid:
videod:
http://www.youtube.com/watch?v=hXMTq1XU ... r_embedded
http://www.youtube.com/watch?v=1bFmEgJN ... r_embedded
http://www.youtube.com/watch?v=d5dwt1g7 ... r_embedded
ENGINES:
xDrive28i
240hp @ 6600rpm
xDrive35i
300hp @ 5800rpm
7000rpm redline
TRANSMISSION:
pildid:
videod:
