E60 esimesed sammud...
Muhv
Postitus Postitas Muhv »
Cardo
Postitus Postitas Cardo »
Kui seda vaatasin siis 3 korda ja ikka ei tahtnud uskuda. Aga kus juht on ?? isegi punast kompotikreemi ei ole näha . Anna jumal kannatust !!
Raivo
Peamine sõiduk: BMW 530D
Postitus Postitas Raivo »
juba jõuti ilus auto ära lõhkuda.
ei tea kas bmw insenerid käisid turva"probleeme" kah autol tsekkimas?
530d
Anti
Postitus Postitas Anti »
http://www.fotoherkner.de/Feuerwehr%202 ... .05.03.htm
Siin on täpsemat juttu ka, kahjuks ei valda Saksa keelt nii hästi, et kõigest aru saaks.
Martti
Postitus Postitas Martti »
Erding : It wanted as fast as possible to the Nachalarmierungsstelle after Erding, which had to be occupied because of the major fire in Lappach with Dorfen that became a 20-year old member of the freiwilligen fire-brigade Langengeisling the calamity. Its car, 55,000 euro an expensive BMW, turned out against 4 o'clock in a right curve on height of the air base Erding to the left from the road, broke through the fence of the German Federal Armed Forces area and a wall and became wedged in an engine room. The driver had to be freed from his fire-brigade colleagues from Erding, Altenerding and Langengeisling with the Rettungsspreizer and the heavy hydraulic equipment, which lasted over one hour. With heaviest head injuries the young man was flown to a hospital to Munich Schwabing.
Altavista tõlkega..
jörgen
Postitus Postitas jörgen »
Sry, tobeda küsimuse pärast, aga kas inimesed elus siis v?
Kui kuidagi ei saa, siis kuidagi ikka saab :)
