Saan aru et tegu taga, esi ja pidurituled. Aga kõik tuled põlevad
Ei viitsi niisama ka külmas neid tulesid lahti lammutada ja hakata uurima kus mida läbi.
Autoks siis E34 525 1994a
Mida arvate teie?
In case you have automatic headlight adjustment: pull the connector from each headlight adjustment motor and see if the faults disappear. If so, condensator helps to control the peaks. Common problem on EURO headligts with the Hella adjustment motors of older design.
Here info how to do from the German E34 forum
http://forum.e34.de/thread.php?threadid=107819
Drawing is easy to understand
LWR Motor = automatic headlight adjustment motor behind the headlights
schwarz = black
schwarz / grau = black/grey
braun = brown
