E60 kaitsmed
Postitatud: 15.10.2011 16:34 00
Postitas diselist
olen värske omanik ja küsin ,kus asuvad kaitsmed sellel autol 04a,530d ja eile andis aku otsad ja pärast olid mõlemad parempoolsed rõngad esituledel pimedad,kuidas seda pirni vms vahetada.
Re: E60 kaitsmed
Postitatud: 15.10.2011 18:19 14
Postitas eclipse
Uus aku tuleb UMs progeda. Kaitsmed pagassi paremas nurgas ja vist oli ka pardatśoki kohal.
Re: E60 kaitsmed
Postitatud: 15.10.2011 20:51 46
Postitas Kustas
WDS kirjutas:Why register the battery replacement?
After fitting a new battery, the service function 'Register battery replacement' should be run. Registration of the battery replacement is necessary to notify the power management (software in the engine electronics and intelligent battery sensor) that a new battery has been fitted in the vehicle.
Without registration of the battery replacement, the power management does not run properly and this can lead to function limitations, for example reduction or deactivation of individual consumer units.
Re: E60 kaitsmed
Postitatud: 24.10.2011 22:49 23
Postitas active steering
Ja kui park pirni vaja siis automaailmast saad 2.50eur tk kui vaja siis saadan ka pirni koodi sulle.
