Uurisin ja puurisin netis ka ringi, aga päris täit selgust ei saanud.
Vaja oleks eemaldada need katted.
Niisama jõuga otse tõmmates ei tule, seal taga küljel peaks olema mingid klambrid.
On kellelgi kogemusi, kuidas midagi lõhkumata nad eemaldada?
Niipalju TIS leidsin:
"Version with luggage pocket:
Pull inside rear panel inwards/backwards (1) and drive outside
forcefully inwards (2) (spring disconnected inside). Press inside of
rear panel outwards and pull outwards/backwards to remove
(outside of spring disconnected) and remove rear panel by pulling
downwards/backwards (3)"
