portos kirjutas:
Kuidas see võtme mälu töötab?2003a.e53 el istmed mäluga kolm originaal võtit ja kaks kasutajat autol
The memory seat buttons are separate from the Key Memory. The Key Memory returns to the last settings from when that key was last used when the doors were locked and unlocked. So to use both systems together, start car and do this:
1. Driver 1 gets in and sets all settings as desired, presses M on seat then memory button 1.
2. Test the setting by pushing memory 1 to see if anyting moves. If nothing moves, you're fine.
3. Lock all the doors and unlock. This sets the Key Memory to that setting, which is now the same as memory button 1.
4. Driver 2 gets in and does the same, but for memory button 2.
The Key Memory can be set at remote unlock, so when Driver 1 presses the unlock button on their key, the position saved above is activated. Same thing happens when Driver 2 presses the unlock button on their key.
The other Key Memory setting is at door open.
In total, you can have more than 3 settings- 3 from the seat memory and one for each key you have.
Google näiteks aitab ka jõuda e53 kasutusjuhendini.
Siin ka veel vähe juttu, mida täpselt saab võtmega teha, erinevate mudelite valikust:
http://www.xoutpost.com/articles/x5/gen ... ation.html" onclick="window.open(this.href);return false;
