Mootorite kaalud
Postitatud: 29.05.2012 00:03 05
Postitas Vosad
Kas kusagilt saaks infot BMW mootorite kaalude kohta?
Äkki on mingi leht, kus on võrdlused vms?!
Re: Mootorite kaalud
Postitatud: 29.05.2012 01:50 56
Postitas Riivo
Iron block M50B20 and M50B25
engine _____ weight(kg) _ weight(lbs)
non-VANOS _ 194 _______ 427.7
VANOS _____ 198 _______ 436.5
http://www.usautoparts.net/bmw/engines/m50.htm" onclick="window.open(this.href);return false;
The US S50 should be the same as the VANOS M50 and the S52 should be very close to this weight as well.
Aluminum block M52B20 and M52B25
engine _______ weight(kg) _ weight(lbs)
VANOS _______ 166 _______ 366
Double VANOS _ 177 _______ 390.2
http://www.usautoparts.net/bmw/engines/m52.htm" onclick="window.open(this.href);return false;
Aluminum block M52B28
VANOS _______ 170 _______ 374.8
Double VANOS _ 180 _______ 396.8
engine _ weight(kg) _ weight(lbs)
M54 ___ 170 _______ 375
http://www.usautoparts.net/bmw/engines/m54.htm" onclick="window.open(this.href);return false;
M60 ___ 210 _______ 463
http://www.usautoparts.net/bmw/engines/m60.htm" onclick="window.open(this.href);return false;
M62
non-VANOS _ 219 _______ 482.8
VANOS _____ 221 _______ 487.2
http://www.usautoparts.net/bmw/engines/m62.htm" onclick="window.open(this.href);return false;
Weights reported by BMW found elsewhere:
S85 ________ 240 _______ 529
http://autospeed.com/cms/title_BMWs-...4/article.html" onclick="window.open(this.href);return false;
S65 ________ 202 _______ 445
http://www.e90fanatics.com/pdf/the_new_bmw_m3.pdf" onclick="window.open(this.href);return false;
S54 ________ 217 _______ 478
(States the the S65 is 15kg/33lbs less than the S54)
N52 ________ 161 ______ 354.9
N54 ________ 195 ______ 430
http://en.wikipedia.org/wiki/BMW_N52" onclick="window.open(this.href);return false;
http://en.wikipedia.org/wiki/BMW_N54" onclick="window.open(this.href);return false;
http://www.mwerks.com/artman/publish...nter_960.shtml" onclick="window.open(this.href);return false;
