Põhjalik ülevaade velgedest, rehvidest ja nende sobivusest.
Anti
Re: Põhjalik ülevaade velgedest, rehvidest ja nende sobivusest.
Postitus Postitas Anti »
leko kirjutas:Oskab keegi öelda, mis veljega on tegu?
Suurus on 17"x8
Replicad.
Originaalis tehti Styling 124 Sternspeiche velge vaid 18-tollisena.
http://felgenkatalog.auto-treff.com/?felge=1240
leko
Postitus Postitas leko »
Anti kirjutas:
Suurus on 17"x8
Replicad.
deeeeem! Aga okei, keegi oskab öelda kust sellist replikat osta saaks:)?
Ise leidsin mingi sellise: http://www.tireman.ee/et/Veljed/p/3879/8633 aga see ei ole ikkagi see sama ju :cry:
Sander.
Peamine sõiduk: BMW 640xd F06
Telefon: 56500423
Postitus Postitas Sander. »
just seesama see ongi, aluteci velg. suht levinud on need replicatena...
leko
Ei ole, seal on kodarate küljed sirged, minu omal ei ole, ja kodarate tagune "rant" on seal astmeline, minul ümar.
Anti
Eks neid replicatootjaid on palju, drewsautos on suht sarnased 8x17" saada
leko
Jep, tänud. Seal on jah kõige sarnasemad. Aga kuna neid kohapeal ei ole siis ei julge igaksjuhuks ette tellida neid. Pealegi replica hind 2150.- on ka suht ulme...
Alpss
Postitus Postitas Alpss »
Mõtlesin, et ehk on vaja siia teemasse: http://www.bimmerforums.co.uk/forum/f83 ... zes-t7759/
1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45
3 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-20
3 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-35
3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30
3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-41
3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47
3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27,
3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45
3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37
5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25
5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20
5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32
5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20
6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20
7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26
7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25
7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 15-25
8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53
X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.
Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread.
Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40
Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52
Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Uued diiselmootorid on mõttetud, 2.4td on tegija!
alarh
Postitus Postitas alarh »
E36 sedaan, M-vedrustus arvatavasti, -15mm. Veljed on 18'' , ees 8,5'' ja taga 10'' laiad, offset kõigil 19. Tiiba ei hakka käima? Rehv on 235 / 40 R18, ei tea kas kõik või esimesed või tagumised.
TiitS
Peamine sõiduk: BMW jt. A+B
Postitus Postitas TiitS »
buumer5
Postitus Postitas buumer5 »
Soov panna Starspoke style 124, 8Jx18 veljele peale rehv 255/45 R18
On kellelgi kogemust, kas saab panna?
Ühes rehvitöökojas öeldi, et soovitud mõõt on 9 laiale veljele sobilik.
Tänud ette!
kenno173
Postitus Postitas kenno173 »
buumer5 kirjutas:Soov panna Starspoke style 124, 8Jx18 veljele peale rehv 255/45 R18
Tänud ette!
Mul on 9,5 tolli, tollele sobib küll hästi peale.
fedja
Peamine sõiduk: MB W447
Postitus Postitas fedja »
alarh kirjutas:E36 sedaan, M-vedrustus arvatavasti, -15mm. Veljed on 18'' , ees 8,5'' ja taga 10'' laiad, offset kõigil 19. Tiiba ei hakka käima? Rehv on 235 / 40 R18, ei tea kas kõik või esimesed või tagumised.
hakkab kohe kindlasti
fedja
Tänud ette!
255 natuke liig sellele.
KonC20
Postitus Postitas KonC20 »
Alpss kirjutas: X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.
Miks?
Alari.
Peamine sõiduk: Bmw e38 730d
Telefon: 5181397
Postitus Postitas Alari. »
Keegi võiks öelda,kui lai siis reaalselt on 215/45/17? Eelpool mainitud jutujärgi siis 215mm??
Ja ntks kui suur laiuse vahe on eelpool öeldud laiuse ja 225/45/17 vahe. kas siis 10mm?
Ja ntk mis vahe on 215/50/17 ja 215/45/17? Üks imelik kummipostimees jahus mulle täna väga imelikku juttu(temasõnul 215/50717 peaks laiem olema vms).Seega kuulaks foorumikasutajate arvamust.
Anti
kickstart
Postitus Postitas kickstart »
Tervist. Mul kah mure rehvidega... Nimelt sain poolmuidu tuttavalt millimeeter mõõdus veljed(aka TRX).
Ei tea, kas neile velgedele on üldse kuskilt rehve saada?? Rehve oleks siis vaja 240/45(või 50) R415 :roll:
MartenL
Peamine sõiduk: Alltrack
Postitus Postitas MartenL »
Esimese posti tabel natuke lihtsamal kujul. Kõrgus tuleb siiski ise leida.
StenV70
Postitus Postitas StenV70 »
Nojaaa....Aga tegelikult on ju nii veel,et tootja mõõdab rehvi laiust "põskede" mitte mustri laiuse järgi...Ehk siis mustri laius võib isegi sama mõõtu kuid erineva kiirusindeksiga rehvidel erineda.
Mida madalama profiiliga rehv on seda laiem mustri osa on.
NT.225/55 r16 rehv on kitsam kui 225/50 r16,mis on omakorda kitsam kui 225/45 r16.
Heikit
Peamine sõiduk: Bmw E60 530xd 2006
Postitus Postitas Heikit »
Kas vahe on väga suur kui panna 235/45/R17 asemel panna 225/50/R17 rehvid, et vastu vast ei hakka käima? :roll:
Bmw E60 530 xd 170kw
Heikit
teab keegi midagi öelda? :roll:
proovi rehvikalkulaatorit mõnda
pasteet
Peamine sõiduk: Accord
Postitus Postitas pasteet »
tere,oleks selline küsimus,et kas e46 328 lähevad 15"veljed alla?
HeavyCuda
Peamine sõiduk: põrkepall
Postitus Postitas HeavyCuda »
BMWfans igatahes näitab, et kõige väiksem mõõt selle auto jaoks on 16" :roll:
e36 coupe in progress.....
pasteet
selge,tänud
MartenL
Vist oligi nii, et 325 läks 15" velg, 328-le juba mitte. Kontrollima ei hakka hetkel
MargusRaska
Peamine sõiduk: E39 530D
Telefon: 55966794
Postitus Postitas MargusRaska »
Oskab keegi öelda palju peaks olema normaalne rehvi rõhk?Autoks E32,730,138 kw.
Tagumised rehvid:265/35 R18,
esimesed rehvid: 235/40 R18.
Neid tabeleid leidsin mitmeid,kuid kõik muus keeles :(
bmwRe39
Peamine sõiduk: BMW X5 e53
Postitus Postitas bmwRe39 »
MargusRaska kirjutas:Oskab keegi öelda palju peaks olema normaalne rehvi rõhk?Autoks E32,730,138 kw.
tuleb vaadata auto uksepostil olevat siltti seal on andmed mis tehas on kaasa andnud.265/35 r18 3.2 ja 2,6
235/40 r18 2.7
sellel leheküljel väike arutelu selle kohta- http://www.allfordmustangs.com/forums/4 ... -18-a.html
Viimati muutis bmwRe39, 10.08.2011 19:05 52, muudetud 1 kord kokku.
Horsepower sells cars, torque wins races - V8-s and diesels
StenV70
KonC20 kirjutas:
Miks?
Selleks,et keegi jahu taguvelgi ette ei tõstaks või veel hullem,diagonaali ei paneks.
isand
Postitus Postitas isand »
Kuidas sõiduomadusi talvel rehvilaius üleüldiselt mõjutab?
Olen varasemalt sõitnud ühe esiveolise masinaga 185 ja 195 laiusega, ütleme nii et oli suhteliselt mõnus. Aga hetkel olen e46 isendile talverehve uurimas ja mõtlen et kas 195 või 205. Sisetunne ütleb, et 195 oleks sõiduomadustelt parem. (kitsam, vähem kontakti maapinnaga) Talvel on tihti ka väga hullud rööpad teedes sees, et kas lai rehv üldse püsib seal sees?
