BMW 5-seeria '2010 F10
Re: BMW 5-seeria '2010 F10
GT on minu meelest ainult pildipeal kole. Reaalselt igapäevaselt nähes on mõnusalt lahmakas lai kulgur.
TanelE34
Peamine sõiduk: BMW Alpina B5
Postitus Postitas TanelE34 »
BMW ALPINA B5 Bi-Turbo EDITION 50
4.4 litre V8 Bi-Turbo 441kW (600hp) 800Nm @ 3500-4500rpm
Tippkiirus: 328 km/h (universaalil 323 km/h)
Ultron
Postitus Postitas Ultron »
TanelE34 kirjutas:4.4 litre V8 Bi-Turbo 441kW (600hp) 800Nm @ 3500-4500rpm
Meie teedel peaks isegi üks X6M 700hp/1050nm seades vurama, turbote sisu pole küll enam originaal.
Üldiselt aga tavaseades 4,4 biturbo N63B44O0 mis 2008-2012 toodeti väga kriitikat töökindluse osas ei kannata ja BMW tegi antud mootoritele paar kuud tagasi tehase tagasikutse
11,09@1/4mile, 300km/h@1mile- e39 540i
dreamstyle
Ultron kirjutas:
ega sa ei motle HKI x6m Typhooni?
kontakt: 53838731
ozzu
Postitus Postitas ozzu »
Ei, see peaks olema all show.
Pigem see punane venelase oma.
koodari
Peamine sõiduk: BMW F10 535iX
Postitus Postitas koodari »
http://www.bmwblog.com/2015/11/24/alpin ... d-you-buy/" onclick="window.open(this.href);return false;
F10 M5 world record ja mäletan nii elavalt veel, kui Lauri Kuriks esimest korda 10sek sisse sõitis... :mrgreen:
http://f10.m5post.com/forums/showthread.php?t=1204640
Roland325
Peamine sõiduk: BMW 650
Postitus Postitas Roland325 »
Päris hea. 0.154 sek veel maha ja pill on 9 sekundi sees. :shock:
My car is a DD... take the kids to school in it!
All of the mods are perfectly streetable - just switch maps based on the gas you are running. The ice-tank really has no benefit other than at the track (and when filled with ice). Pure S1 provides more airflow upto around 6K RPM, after that seems it (and the stock) are turbine limited.
Regarding weight - pass seat comes off at the track (its probably 65lbs. Figure race-weight (me + gas) is 4500. Car had 1000hp for this pass. The hp calculators are pretty spot on.
Plekkvelg
Peamine sõiduk: BMW 320dA '05 tour
Telefon: 53313855
Postitus Postitas Plekkvelg »
Kas digitaalne spidokas (digital cluster) oli lisa või luksuliku paketi osa? LCI hakkasid üldse need peale tulema nagu ma aru saan.
Lisavarustus.
Buumer Auto / 53302262
