320. leht 456-st
Postitatud: 05.10.2016 22:10 05
Postitas VerineVelg
Postitatud: 06.10.2016 10:24 07
Postitas kaspar
Postitatud: 06.10.2016 10:34 34
Postitas S1lv3r
Veidi käredam ikka kui tavaline 320i. Need erimudelid on kõik m-paketid.
S1lv3r kirjutas:
Esmapilgul tunduvad kõik olema täis m-paketiga.
Tegu on iseenesest päris huvitava pilliga ehk 320si 127kw. Arvasin algul, et omanik üritanud vähe atraktiivsemaks üritanud kuulutust teha, kuid wikist leidsin infot.
It is a limited (2600 units) version of 3 Series saloon built to qualify the homologation requirement for the FIA World Touring Car Championship (WTCC).[36] The 320si uses a modified 4-cylinder engine (N45) different from the standard 320i (N46). Modifications include an increased redline to 7.300 rpm, a shortened stroke (by 2 mm), an increased bore (by 1 mm) and a higher compression ratio (11,0:1). The engine is mostly hand-built and does not have Valvetronic, decreasing the number of moving parts. Acceleration from 0 to 100 km/h (62 mph) takes 8.1 seconds and acceleration in fourth gear from 80 km/h (50 mph) to 120 km/h (75 mph) takes 7.7 seconds compared with a standard 320i which achieves them in 9.0 and 9.1 seconds respectively. Fourth gear acceleration is comparable to that of the 325i which achieves the 80 to 120 km/h (50 to 75 mph) sprint in 7.5 seconds. BMW WTCC works driver Andy Priaulx won two of his three consecutive World Championships in the 320si E90 as well as four other drivers achieving over 35 wins in the championship since the cars release.
The BMW 320si is used by a few teams in the British Touring Car Championship (BTCC). Colin Turkington won the 2009 BTCC Drivers championship using the BMW 320si.
Postitatud: 06.10.2016 10:48 37
Postitas kaspar
Oo, tänan info eest, sain ka targemaks
Keegi, kes e90 otsib, võtke ära
Postitatud: 06.10.2016 10:53 21
Postitas Jaakk
Väga ei soovita seda si-d osta kui mootorit ei taha remontida.
Huvitavad BMW müügikuulutused
Postitatud: 06.10.2016 11:01 52
Postitas S1lv3r
Kahjuks ei ole neil mootorid kõige vastupidavamad...
Mingiaeg sai neid Saksast piilutud ja enamus olid mootoririkkega.
Postitatud: 06.10.2016 11:46 32
Postitas oo7
http://www.hthoward.co.uk/engine-machin ... k-repairs/" onclick="window.open(this.href);return false;
Seda kuidas täpselt sama ettevõte suutis teha ~15a varem 320iS mis arendab 141kw ja põhineb äärmiselt tugeval ja suurte silindrivahedega M10-l ja hiljem sellise nikerdise jääb selgusetuks
Postitatud: 06.10.2016 12:31 12
Postitas Maario80
Tundub sama auto mis leedu platsil paar kuud tagasi seisis
Postitatud: 06.10.2016 20:23 33
Postitas mkb
Lk 304:
Jaakk kirjutas:Nagu sa isegi tead siis need si autod ei hiilga just oma mootori vastupidavuse poolest. Mobiles oli vahepeal vähemalt 10 autot saada millel kõigil kas mootor päris laiali või kolin sees.
S1lv3r kirjutas:Korra varemgi Eestis 320si müügis olnud. Pakkus täitsa huvi, aga uurides selgus, et enamus mis saksas müügus olid mootoririkkega ja ei pidavat väga kestma...
oo7 kirjutas:Tundub veidi müstiline et 25a tagasi suutis sama autotootja teha 320iS, millel on 141kw ja mootor äärmiselt vastupidaval M10-l põhinev S14. Nüüd ei suuda isegi seda jõudu välja anda ja ei kesta ka
Deja vu.
Postitatud: 06.10.2016 20:52 07
Postitas S1lv3r
Nii? Oleks pidanud vahepeal uue jutu välja mõtlema?
Tuleb ka järgmisele sama vastus, kes asjaga kursis pole
Postitatud: 06.10.2016 20:55 55
Postitas mkb
Ega midagi katki polegi, aga tundus kuidagi tuttav see jutt. Otsima hakates oli isegi kaader sama.
Rivitult.
Postitatud: 06.10.2016 21:02 14
Postitas oo7
Kordamine on tarkuse ema,
Next time kui asi üles kerkib võid uuesti kopeerida
Postitatud: 06.10.2016 21:02 51
Postitas -myyr-
http://www.auto24.ee/used/2238660" onclick="window.open(this.href);return false;
hahahah
Ehk pole läbi käinud
Postitatud: 06.10.2016 21:48 19
Postitas VerineVelg
Postitatud: 06.10.2016 21:49 40
Postitas S1lv3r
Foorumihunt rasskalbass ju
Postitatud: 06.10.2016 22:01 19
Postitas VerineVelg
Postitatud: 06.10.2016 23:58 47
Postitas JanekEnde
Ülikena ikka
Postitatud: 07.10.2016 22:03 03
Postitas Harru
Kurikuulus x6 M valmis saanud ja juba müügis, kahju. Aga minu meelest ülikõva tulemus!
Postitatud: 08.10.2016 05:13 11
Postitas RazzKalbass
Ei ole veel päris valmis, kohe saab stanged ka külge, muud pudinad on küljes.
Postitatud: 08.10.2016 23:58 05
Postitas Miskitrohelist
Harru kirjutas:Kurikuulus x6 M valmis saanud ja juba müügis, kahju. Aga minu meelest ülikõva tulemus!
miskil põhjusel vöörandamis keeluga.
Postitatud: 09.10.2016 16:33 40
Postitas raunoh
Miskitrohelist kirjutas:Harru kirjutas:Kurikuulus x6 M valmis saanud ja juba müügis, kahju. Aga minu meelest ülikõva tulemus!
järjest paugutatakse teemasid, mis mõni hetk tagasi juba läbi käinud
Postitatud: 09.10.2016 16:58 51
Postitas Tauri_J
siit teemast mopiga üle käidud
Postitatud: 09.10.2016 17:05 55
Postitas raunoh
Tauri_J kirjutas:
krt nii ongi
Postitatud: 09.10.2016 19:59 09
Postitas JanekEnde
Oli ka aeg.
Postitatud: 10.10.2016 21:35 12
Postitas VerineVelg
Postitatud: 10.10.2016 22:14 28
Postitas kekuleku
Käisin vaatamas kuu tagasi. Vajab investeeringut mootori tuli põles, roolivõim ei töötanud korralikult, kliima ei töötanud, armatuur imelikult tehtud, tagastange istus imelikult.
Postitatud: 12.10.2016 04:24 55
Postitas -myyr-
asi minus, või lihtsalt liiga odav
http://www.auto24.ee/kasutatud/auto.php ... rhash=d848" onclick="window.open(this.href);return false;
Postitatud: 12.10.2016 08:36 01
Postitas Oliver.L
Paras hind auto vanust ja läbisõitu vaadates minu arust. Full options, aga musta lage, head up displeid, katuseluuki ikka ei silma.
Postitatud: 12.10.2016 10:36 55
Postitas Henri.
See auto nii tihti müügis, et kas a) on korralik "rändkarikas" või b) ei õnnestu müüjal sellest kunagi lahti saada ja pidevalt uued kuulutused.
Postitatud: 12.10.2016 11:40 09
Postitas S1lv3r
Omanikuvahetusi paar tükki on, aga müügis jah pidevalt olnud... odavat ei ole seal midagi.
Paras puzzle on
